- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have the same issue as Tammy, as so I tried a number of things along the lines of what you suggest about windows controlling the cursor. And none had any effect. See the first SS where I show some of the exaggerated the color and the thickness of the, then look at the second SS and note that it is a where's Waldo to even see the cursor in the text editor. And just to show that the Settings took, look at the last SS where I then went to do a save file. So AutoCAD blocks the ability of Windows to change the Cursor features. I also did a number of combinations of the Widows settings with features on and off and the AutoCAD Cursor is unchanged. And I have also looked into changing background colors and the cursor remains grey in all cases. AutoCAD has to have some place where they control this cursor, just where that is, is yet to be determined. I started using AutoCAD with version 2.X in the 80's and I have been able to solve almost every issue or find a work around except this one. I will likely be retired before I find a solution.
