pinnacledrafting
513 Vistas, 6 Respuestas
floating windows command line
As shown in the What's new in Autocad 2023 the floating windows are supposed to have its own command window. Mine does not do that. I thought maybe it was because I anchor my command window but that is not the case. What am I missing, is there a variable setting? or some hidden menu somewhere?
Thanks in advance,
Bill.
imadHabash
en respuesta a: pinnacledrafting
Would you please show us a screen shot image .. and describe more your issue ?
Imad Habash
RobDraw
It needs to be anchored according to this.
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-863D23E8-4651-41B8-A48A-85D2E32C5AA5
Rob
pinnacledrafting
en respuesta a: imadHabash
@imadHabash , attached is a screen shot. You can see that only the main window has a command line, the floating window does not. The floating window is pinned and active.
pendean
@pinnacledrafting Do you have the latest 2023 update installed? If that still does not fix it then start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
pinnacledrafting
en respuesta a: pendean
I think I figured it out and it's really dumb. For some reason, the command window cannot be anchored all the way across the bottom. It can be most of the way but it can't touch the sides of the screen. You can anchor right, left or bottom, but only one.
Thanks for your help.
RobDraw
You're welcome.
Rob
