dominicEQKHG
902 Vistas, 6 Respuestas
Annotative Dimensions not appearing
I've added annotative dims in model space that do not appear in paper space.  Both annotative scale and viewport are the same and the layer is thawed in the viewport.  Moving the dimensions to another layer that is switched on doesn't change anything.  The odd thing is, if I switch to paperspace and enter the viewport, I can add a dimension that remains visible.
Any idea what I'm missing?  Thanks for any advice.
pendean
en respuesta a: dominicEQKHG
Show us: share your actual DWG file (or a portion that still has the problem in it) with the problem please.
imadHabash
I suggest to check ANNOALLVISIBLE = 1   and/or  from Layer Properties dialog check VP Freeze tab .
Imad Habash
dominicEQKHG
en respuesta a: imadHabash
Thanks, annoallvisible was set to 0.
satoshiq
Thank you so much! That’s exactly what I needed.
But seriously, why does AutoCAD have so many confusing functions?
pendean
en respuesta a: satoshiq
@satoshiq wrote:
...But seriously, why does AutoCAD have so many confusing functions?
AutoCAD has many many controls and options, a lot: like a huge amount. They can be confusing if you don't have the time to look them all up (or at least know how to look them up in the equally confusing HELP in the program).
satoshiq
en respuesta a: pendean
Yeah, I feel like they add a bunch of new things every year, while also keeping a lot of the old stuff(or even every single one). It makes everything confusing.
