Kent1Cooper
en respuesta a: je2525
It's an alternative command name.  There are others [for example, DELETE (spelled out -- not the Delete key) is not listed as a command name in Help either, but it works, giving you the ERASE command].  The command line shows the "real" command name you're going to get when you type one in:
But I haven't been able to find a listing of them, either, maybe because I don't know what they're officially called [except not "alias"] -- are they "alternative" command names? "substitute"? "equivalent"? "stand-in"? "proxy"?
Kent Cooper, AIA
