Alfred.NESWADBA
en respuesta a: dtucker
You can select the text objects using normal selection like window or crossing (or fence or ..), so no need to click any single text object with a single click.
>> into individual MTEXT strings
That can't be done automatically as AutoCAD does not know with text objects belong together and which one should be appended to another MTEXT object.
If you have 100 text objects and from them there should be 12 mtext objects created ... what is the rule which ones belong together?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
