- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I need to convert a couple hundred individual DTEXT strings into individual MTEXT strings. I know to use the Express Tools command, but the only way I can see to do this is one text string at a time.
Is there another way to accomplish this?
Dan
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can select the text objects using normal selection like window or crossing (or fence or ..), so no need to click any single text object with a single click.
That can't be done automatically as AutoCAD does not know with text objects belong together and which one should be appended to another MTEXT object.
If you have 100 text objects and from them there should be 12 mtext objects created ... what is the rule which ones belong together?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The only point, it seems to me, in converting dtext to mtext is to group the lines of dtext that are related to one another into a paragraph. Just changing a single line dtext to a single line mtext has little point. To correctly group the text objects to form paragraphs requires interaction by the user who understands what is being said. Perhaps IBM's Watson can be given that task but I doubt that automating it would be an efficient use of time.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Anonymous wrote:
The only point, it seems to me, in converting dtext to mtext is to group the lines of dtext that are related to one another into a paragraph. Just changing a single line dtext to a single line mtext has little point. ....
... unless you want to be able to have stacked fractions in it, or want to change the color or font or height or italicization [is that a word?] of a portion of it, or....
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
True. I generally avoid all those options, believing that text is more readable without stacked fractions, special colors, or special embedded fonts. If that level of individual control is desired however, converting dtext to mext automatically is the least of his worries and the least possible to automate.
