Kent1Cooper
en respuesta a: BuckSurf
I don't know of any setting or automatic way to do that, but I made a command to do it, the DET command in DimExtLineToggle.lsp, >here<.  You pick on a Dimension anywhere on it closer to the extension line you want to toggle, and it turns that one off if it's on, or on if it's off.  So you don't need to know which end is extension line 1 and which is 2, as you would to do it in the Properties palette.
Kent Cooper, AIA
