Alfred.NESWADBA
en respuesta a: Jan-TSpD
>> Is it possible to change this background to transparant?
I would guess if you turn the Excel's background to black you would get a black background in your OLE object ... :cara_guiñando_un_ojo:
Other question: it seems you are working with a black background in AutoCAD (I guess that's the reason why you ask here for none-white background), would you see black text (from Excel) when you insert the OLE-object with transparent background to AutoCAD's graphic with black background?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
