sdvannelli
en respuesta a: sdvannelli
Here is a screencast of it happening by using control to make the copy. I also have had it happen using the right click menu, which I will post as a follow up screencast. If you try it and it works fine, try it a few more times on different tabs to see if you can recreate it. Sometimes it works fine for me, and others it does this.
