en respuesta a: Anonymous
Jen,
See if you can hatch this box (Drawing attached)
Just open the drawing and select the hatch icon.
Use the default hatch pattern
Use "Select Object"
Select Object, then <ENTER> or right Click
Then select <OK>
The hatch should appear.
If you can not do this in your drawing maybe your object is not at ZERO elevation
Hope this helps
Ron
