Weirder still. (I have included all mentioned files for you to have a gander at).
I made a new file in inches and that file is called "TEST FILE A - Inches.dwg".
I made a test file in US Survey Feet (I just drew a box around the site in the original file and deleted everything else). That file is "TEST FILE B - US Survey Feet.dwg".
I then inserted "TEST FILE B - US Survey Feet" into "TEST FILE A - Inches" at 0,0. As you can see, the units/scaling are correct:
I then xrefed "TEST FILE B - US Survey Feet" into "TEST FILE A - Inches" at 0,0. As you can see, the units/scaling are correct:
Now however, in TEST FILE A - Inches, the block (in red) is 1/12th the size of the xrefs (yellow).
The block's units read as inches:
The xref's units read correctly as US Survey Feet
