03-22-2022
12:46 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-22-2022
12:46 PM
Hi @lesley.morrey,
Welcome to the AutoCAD forums community!
Thank you for providing your drawing, I may have found a couple things:
The upper line is 2 lines, the line on the right crosses the top of the solid, the one on the left is only part of the outline of the region area.
I am seeing the same error, and when I view from the Right side, the darker section of lines shows they are not all on the same plane. The gap is visible if you zoom zoom in further, this view is not as I wanted to provide other parts for reference.
This may be the one that is offset:
I would start with redrawing the lines, then check the solids if your snap points are still off.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
