andy54QXE
en respuesta a: AutoMarcus
This worked for me when using Bluebeam to view cad drawings that need to have viewable different transparency values.
select the page tab you want to Publish and apply already defined transparency value. (I had 6 tabs as part of my drawing set including the cover page, and had to select and use this method for each tab individually.)
Type - PAGESETUP
The tab you have opened will appear highlighted, select - MODIFY...
Select the plot option - PLOT TRANSPARENCY
Click - OK
Now when you PUBLISH, the transparency values in that tab will publish to your Bluebeam PDF.
-Good luck.
