rkmcswain
en respuesta a: kdacostaZZD8D
I wonder if that when you renamed it @kdacostaZZD8D - if you did not have file extensions visible - in that case, what actually happened is the file went from "mydrawing.bak" to "mydrawing.dwg.bak".
If you enable file extensions, you will see/check on that.
