03-17-2022
04:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-17-2022
04:02 AM
Thank you for clarifying. The default application to open DWG files is correctly set per the provided link.
I also tried turning off background publishing. A new cad application still opens when publishing, but now as both a tab in the drawing i had open previously and also it tries to open it as a new window as well causing sheet set to crash I assume because it is trying to open the same file twice (once as a tab and a second as the new window). Also, the "Publish Job Progress" pop up opens and runs while the sheet set application is running. I assume this is the foreground method of plotting.
