e.alshayb
2179 Vistas, 3 Respuestas
angle with tab
so when I drow a line then I need to just click the tab then will be able to change the angle
I try to do this but did not work at the school PC
but on my PC, I can do that
ChicagoLooper
en respuesta a: e.alshayb
Sorry I don't understand. Do you mean you want to enter an angle like the one you've highlighted in blue? If that's what you want to do, then hit F12.
Hitting F12 will give you the white 'box' where you can enter an angle.
If that's not what you want, then please explain again.
Chicagolooper
leeminardi
It sounds like you may need to set dynmode  to 1 to enable the tab key to put you into the length-angle mode of entering a coordinate.
lee.minardi
ennujozlagam
just press F12 in your keyboard and you can key-in your desire angle? thanks
