micahfraley
424 Vistas, 6 Respuestas
"Publish to PDF" in Sheet Set Manager, Autocad opens a new window cad file
When selecting "Publish to PDF" in Sheet Set Manager, Autocad (specifically I am working in Civil3D 2022) opens a new window cad file of each drawing as it is being published to PDF. In previous versions, this has not occurred, the manager ran in the background without opening any files.
Each of my projects is set up with typically three cad files that the sheet set manager references. One file with the title sheet and all detail sheets, a second file with the plan pages (site plans, grading plans, etc.), and a third with the road profiles. When plotting to PDF, as each page's PDF is being created, Autocad opens a new window of cad with that file, plots the PDFs that are in that file, then automatically closes that cad file. If I have the file open already when the sheet set manager is running, it does not open a new window when publishing each PDF. Note that my "plot and publish" options are already set to background plot for both plotting and publishing. I have not changed any settings for plotting from my previous versions of Civil3D.
I'm not sure if its related, but the new window of cad opens with the Layout Tools "Task Pane" window open. That window is not open typically in my day to day use of Civil3D.
