pendean
en respuesta a: grufin4XYSP
Do you have an outside ARG profile file being loaded at startup?
Are you just using plain AutoCAD? Or a variant?
RESET AutoCAD if re-entering the default location does not fix it, see example below assuming R2021 is in use
C:\Users\YOURLOGINNAMEHERE\AppData\Roaming\Autodesk\AutoCAD 2021\R24.0\enu\Support\ToolPalette
In the future simply ADD your custom folder instead  of replacing the stock/default item, then "MOVE UP" the list if needed.
