- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Can't delete Tool Palette file location
I've been working setting it up a new tool palettes for my office. I've change the name of the folder where I was telling AutoCad to get the palettes from (.atc files), now I'm trying to delete that path on the tool palettes files location in the Cad options, (using Autocad 19) but it keeps coming back everytime I reopen the options. Some of the solutions I read was to reset AutoCad back to default properties and reinsert all the paths again. Was wondering if there is any other solution to this?
Thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Do you have an outside ARG profile file being loaded at startup?
Are you just using plain AutoCAD? Or a variant?
RESET AutoCAD if re-entering the default location does not fix it, see example below assuming R2021 is in use
C:\Users\YOURLOGINNAMEHERE\AppData\Roaming\Autodesk\AutoCAD 2021\R24.0\enu\Support\ToolPalette
In the future simply ADD your custom folder instead of replacing the stock/default item, then "MOVE UP" the list if needed.
