MarkFitz
462 Vistas, 7 Respuestas
PDF Whiteout - Good Example
A month or so ago, I posted a question in the forum about having a PDF that when converted into CAD, had an all white background that covered most of the actual detail. Part of the problem of reconciling this issue was that the PDF in question was one page of a PDF document. I now have a prime example of the issue so I'm sending the PDF with this request to see if we can work the actual problem out.
If you see what I see once converted to CAD, then all you see is a white background no border with a handful of drawings of windows and doors, but no dimensions. If you choose a command to adjust the image, like erase for example, then hover your cursor over the drawing, you will see the details appear. My question is, how do I get rid of the white but keep the details?
