toon.cardeynaels
491 Vistas, 3 Respuestas
Automatic drawing Autocad
I was wondering if it would be possible to let Autocad draw automatic sketches by giving a few values in a box.
This box could be the same as a 'Attributes box' as already known by using with blocks. Only my idea is to set levels of building floors as drawing lines with the correct offset to eachother by using the giving values in the box. With this sketch it is easy to see the levels of each floors, the levels of each finished level, dimensions of the elevator shaft, level of cantilevered terraces, etc... Below my sketch, hand drawn for a small apartment building.
Anyone some ideas?
