sumarid
710 Vistas, 6 Respuestas
Batch plot issues in 2022
Good day
We've been batch plotting engineering drawings to PDF with AutoCAD 2017 without issues, but have recently transitioned to 2022. No matter what we do, it takes 2min per drawing (compared to roughly 15 seconds with 2017). We import a standardized drawing with all the types of PDF styles we use (A3 or A0 etc), and generated a similar one for 2022. But no matter what PDF printer we use (Cutepdf/dwg to pdf, microsoft pdf) it makes no difference to the timescale. Sometimes it runs for 24hrs and doesn't complete the last couple of drawings.
Has anyone had similar issues?
maratovich
en respuesta a: sumarid
AutoCAD for publishing always uses  AutoCAD PDF (General Documentation).pc3
Only this printer, no matter which printer you choose.
This printer has a very high print quality by default.
Therefore, the files are very large and it takes a long time to make them.
Change the print quality to 600 dpi.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
sumarid
en respuesta a: maratovich
Hi
Thank you for replying. I did what you said, but it had no effect on the time...
Valentin-WSP
@sumarid ,
Welcome to the forum.
I would suggest you perform the suggestions on these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
maratovich
You are trying to change the publish settings, but this does not affect the quality.
The quality is set in the printer settings.
You need to change the settings in the AutoCAD PDF (General Documentation).pc3 printer
www.kdmsoft.net
pendean
... also ensure you turn off background publishing and plotting. It is on by default.
sumarid
Thank you everyone. The problem turned out to be publishing in background was checked on. It was on in the past with 2017 and didn't give issues, but now it did.
