andy.clegg
300 Vistas, 2 Respuestas
Complex Linetypes
I need to create two complex line types without the use of shape files, please see attached.  Any guidance would be appreciated.
Valentin-WSP
en respuesta a: andy.clegg
@andy.clegg ,
Consider using WINGDING fonts. Check out the attached PDF pg.12 onward.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Kent1Cooper
@andy.clegg wrote:
... without the use of shape files, ....
Is there some reason that shape files are not wanted?  What makes the use of them any "worse" than the use of an embedded text element [which is your only other option]?
Kent Cooper, AIA
