- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
RECOVER reports 0 error but ACAD still..
Here is the prob:
Once opened, ACAD prompts "XXX error found ... ". So I closed it & RECOVERed it and ACAD prompted "0 error found 0 fixed". And this ERROR message keeps on haunting this particular dwg.
What can I do next? Help!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@nodink ,
Try these suggestions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
RECOVER->AUDIT-> -PURGE RegApps -> -Purge All -> qsave
As further test:
WBLOCK option OBJECT selection
Try it with the new file you created by WBLOCK
and so on.
Share you file if you want help.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If all else fails you can saveas a DXF file close it then reopen and save as a drawing. I would only use this as a last resort though.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Good Idea!
Note: Saving in DXF is not a problem, but use the same or the name format of your productversion.
(If you have ACAD2018, and the file is dwg2018, then saveas dxf2018 - this should be safe)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes,
if you won't share your Etransmit package, so WE can search for the issue and a solution.
Without the data, we can give general hints.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@nodink then do this... start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
