- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @glomauro
>>" Why Autocad accept 3rd parts regap?"
Because users like to use program extensions!
Because users like to use other application (based / on top of autoCAD)!
Because AutoDESK loves that other companies using AutoCAD as core product for there appliaktions = more installs = more PR = more money
PS: You forgot to show us from which application we are talking.
And: Are they in use or purgeable?
Can you share 10 names (or the whole list as txt file), or much better: This DWG?
>>"this is ignorant"
No, this is part of usual program internals.
But the count of 100000+ RegApps sounds that the programmer use a very special way.
I know one Application for german architecture tools which uses regapps in mass.
(the question: Why? Was answered with: This data structure ist the fastest for my needs)
>>" but if was a programmer I would avoid."
Because you didn't understand for what you (programmes) can (and have to) use regapps data,
you don't see all the connections but at most only your own situation - and that's not entirely certain either.
or I am wrong, but you sounds this way
>>"Someone says is a Autodesk trouble vs the cyber pirates, we are not cyber pirates
Nonsense
Upload your DWG, perhaps we can help you for a better handling
For Xrefs (only) you can use XREFREGAPPCTL
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-71F86DA9-D519-418A-B8F6-8A6A5D920EF9
and use Purge or another tool to purge unused Regapps
in you source files (so you don't copy them over and over again by clipboard or insert)
Sebastian
