dbroad
en respuesta a: CovenStine
To add to what @dmfrazier said, if you must have square dots in a linetype, then you need to:
  1. Add a linetype definition that uses very short dash strokes (0.02) instead of dots (0).  Make your "dots" as long as you want the lineweight to plot. The 0.02 length would work for a 0.5mm lineweight.
  2. Adjust your plot style to use square ends.
I think this was an oversight on the part of the AutoCAD developers but I don't expect any change from them.
Unfortunately, this makes your linetypes very specific as far as lineweights.  Use the MKLTYPE command to ease the work involved.
Architect, Registered NC, VA, SC, & GA.
