glomauro
436 Vistas, 6 Respuestas
regapps return
Did you think to permanently eliminate them?
TADAAA
REGAPPS RETURN!
Are only 16900 instead of 132600, but return.
Congratulations to the AUTODESK programmers for their useful work
***THE POST AND TITLE HAS BEEN EDITED FOR CLARITY***
cadffm
en respuesta a: glomauro
More context please (a Link?) - for ignorant readers like me.
Sebastian
RSomppi
Do you mean REGAPPS? They are added by 3rd party programs, not AutoCAD.
glomauro
en respuesta a: RSomppi
Why Autocad accept 3rd parts regap? this is ignorant and say recap, but if was a programmer I would avoid.
Someone says is a Autodesk trouble vs the cyber pirates, we are not cyber pirates
cadffm
Hi @glomauro
>>" Why Autocad accept 3rd parts regap?"
Because users like to use program extensions!
Because users like to use other application (based / on top of autoCAD)!
Because AutoDESK loves that other companies using AutoCAD as core product for there appliaktions = more installs = more PR = more money
PS: You forgot to show us from which application we are talking.
And: Are they in use or purgeable?
Can you share 10 names (or the whole list as txt file), or much better: This DWG?
>>"this is ignorant"
No, this is part of usual program internals.
But the count of 100000+ RegApps sounds that the programmer use a very special way.
I know one Application for german architecture tools which uses regapps in mass.
(the question: Why? Was answered with: This data structure ist the fastest for my needs)
>>" but if was a programmer I would avoid."
Because you didn't understand for what you (programmes) can (and have to) use regapps data,
you don't see all the connections but at most only your own situation - and that's not entirely certain either.
or I am wrong, but you sounds this way
>>"Someone says is a Autodesk trouble vs the cyber pirates, we are not cyber pirates
Nonsense
Upload your DWG, perhaps we can help you for a better handling
For Xrefs (only) you can use  XREFREGAPPCTL
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-71F86DA9-D519-418A-B8F6-8A6A5D920EF9
and use Purge or another tool to purge unused Regapps
in you source files (so you don't copy them over and over again by clipboard or insert)
Sebastian
RSomppi
What? You are hard to understand.
