j.palmeL29YX
en respuesta a: rudirossouw
It is the normal behavior of AutoCad, that the extrusion results in surfaces (instead of solid) if the source contour is not an exact plan shape.
To be sure that this condition is fulfilled either use 2D-Polylines or create Regions from your 3DPolylines.
If you don't get Regions you can be sure, that the contour is not exact plan.
In this case you can extrude the 3DPolylines first to surfaces. Then try to "close" the open ends (e.g. using the surfpatch command or others) and then convert the surfaces into a solid (convtosurface or sculpt ccommand).
[EDIT]: This >>example video<< added
Jürgen Palme
