dmfrazier
en respuesta a: CovenStine
I think the dot in the line will always appear rounded, regardless of the method used to display or plot line thickness/weight/width, because it is a dot.  There may be a way (as you suggest) to define a linetype with a very short "dash" that can be made to display and/or plot square.
As far as the Line End Style, if you're plotting with plot styles, you can specify square ends in the plot style table.
