- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
A problem similar to Andrew's. While in the BLOCKS PALETTE, the Current Drawing tab, if I right click a block, the option to Copy to Favorites, is greyed out and unavailable.
I was really loving this option just a few days ago.
I copied that folder (C:\Users\cspen\AppData\Roaming\Autodesk\AutoCAD 2022\R24.1\enu\FavoriteBlocks - Copy)
right beside it-self to do a bunch of editing on the blocks and their names.
Now the Favorites tab in the BLOCKS PALLETTE is empty. Curious and annoying.
Help. Please. Spence Ball, Silver Spring, MD USA
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@spence7 ,
Check your file path in the Options > Block Sync Folder Location:
Try the suggestion provided on the help.
Also, take note:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Tried that, but no. I could not quite get it to work.
But like so many things, a work-around was found.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
My work-around is to load all my favorite blocks into the LIBRARY tab of the Blocks Palette instead of the FAVORITES tab. For reasons hard to define I fancy the Blocks Palette over Tool Palette or design center.
Thank You.
