731 Vistas, 2 Respuestas
sudden error with 3200 x 1800 display resolution
I recently updated to Windows 10 and autocad was working well.
The next day, I started having resolution problems, where the command line (and some parte) are weirdly HUGE:
http://s12.postimg.org/m3l8w5isd/autocad_resolution_problem.png
I even tried this fix I used in Windows 8.1: http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
But it's not working.
I'm a bit desperate as I'm not good at coding or stuff yet I find no easy solution for this problem.
I saw this link too: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gr...
Tried them, yet it's not working. The first step is impossible otherwise I don't read anything in the computer.
Edit: Just discovered this post: https://forums.autodesk.com/t5/autocad-lt-general-discussion/high-resolution-display-for-lt-2015-and...
Is this real? I'm not going to be able to use autocad properly in this recently purchased computer for at least a couple of years?
