AutoMarcus
538 Vistas, 3 Respuestas
coordination model xref not plotting or visible in viewport
Hi All
I have a large NWD file that i have inserted into a model file
I have then xreffed the model file into my drawing as a background.
in model space the model is only visible when zoomed out, when i zoom in it dissapears.
it is not visible in paperspace at all, even with realistic or conceptual visual styles for the viewport.
anyone have any ideas?
Zlatislav.atanasov
en respuesta a: AutoMarcus
Hi @AutoMarcus
I am not familiar with NWD files, however, this sounds similar to a problem I had with surfaces in Civil 3D. Maybe the problem is "level of detail" that is located under View>Views>Level of detail. Missing Contours in Civil 3d. Hope it helps.
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
https://skillamplifier.com/
Amplify your skills to a new level!
AutoMarcus
en respuesta a: Zlatislav.atanasov
Thanks for your help  Zlatislav.atanasov
Ill check it out
Valentin-WSP
@AutoMarcus ,
Try the suggestions from these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
