- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
As I wrote:
"i think you not just added two new attdefs, the you also deleted or renamed others!"
(Or if you are not the creator of the old block, another one did it)
See my picture, older Blockreference has Attribut NAME and NUMBER,
but I am missing they in your current blockdefinition.
In you current Blockdefinition I can see LAB-NAME and SPACE-NUMBER (what is not the same.. is like Peter and Marry, both are names, but not the same
I posted also the solution in this case:
"Make sure you have ALL needed attdefs in your block definition(same name as attributes on existing blockreference)."
a) If you do that, you have a Block with NAME,NUMBER,AREA,LAB-ENGINEER and LAB-MANAGER,,
use ATTSYNC now!
b) Next step, I guess you want to rename NAME->LAB-NAME and NUMBER->SPACE-NUMBER,
use command BATTMAN, make sure that the [Settings..] option to apply edits to existing Blockreference are ON
Sebastian
