- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
The block on the left is my new block the one on the right is the old block
The name is the same "AREA-TAG" I added 2 new attributes to the one on the left
I did an Insert & Redefine and the block comes in but does not change any of the existing
blocks. If I do an block insert now I see the new info, the old blocks still stay the same.
How can I get the existing blocks to update to show the new attribute information?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In this case (we have to guess because you forget to attach your dwg)
i think you not just added two new attdefs,
the you also deleted or renamed others!
Or if you are not the creator of the old block, another one did it.
Make sure you have ALL needed attdefs in your block definition(same name as attributes on existing blockreference).
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As I wrote:
"i think you not just added two new attdefs, the you also deleted or renamed others!"
(Or if you are not the creator of the old block, another one did it)
See my picture, older Blockreference has Attribut NAME and NUMBER,
but I am missing they in your current blockdefinition.
In you current Blockdefinition I can see LAB-NAME and SPACE-NUMBER (what is not the same.. is like Peter and Marry, both are names, but not the same
I posted also the solution in this case:
"Make sure you have ALL needed attdefs in your block definition(same name as attributes on existing blockreference)."
a) If you do that, you have a Block with NAME,NUMBER,AREA,LAB-ENGINEER and LAB-MANAGER,,
use ATTSYNC now!
b) Next step, I guess you want to rename NAME->LAB-NAME and NUMBER->SPACE-NUMBER,
use command BATTMAN, make sure that the [Settings..] option to apply edits to existing Blockreference are ON
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can use command BATTMAN - Edit to change the attribute name first, then edit the block and add 2 extra attributes, then use BATTMAN - Sync again to update all blocks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
