vinodkl
en respuesta a: noli1057
Hi @noli1057
You would face this issue if you have larger number of blocks in the drawing and block search options is enabled.
Try this: Type in the command "INPUTSEARCHOPTIONS" and then you can uncheck "search content at command line" or just uncheck "block" in content type. You could also uncheck "layer" if you have lots of layers in the drawing and don't want command line to search for layers ad well :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
