cadffm
en respuesta a: rkhan1L79CX
If you have the same issue, the solution is also the same
If in PDF or paper the lines are gray (this was the issue in this thread and you saying you have the same problem, so your line IN PDF are not black.
Then your color is NOT 7
as is wrote
And if your lines in PDF or paper are black and you have trouble in Acad layout tab only,
then change the background color of paperspace or live with that.
All possible cases already said,
now you have to understand and testing (or change screenshot and dwg, so we can take a look for you)
a) only in Layout, but not in PDF/Paper? -> Layout background color
  or
b) also in PDF/paper gray but only if printed from layout and not from model? Check your plotstyletable in your layout
Sebastian
