engineersafiullah5
455 Vistas, 2 Respuestas
importing pdf into autocad not working
i am using Autocad 2018 , But When i import my PDF file, (which contains a lot of text), that is not converted to text But convert to Geometry (hatched) , which is very difficult to convert to text.
So please help me , i am attaching my pdf file
Etiquetas (3)
Etiquetas (1)
the PDF does not contain text, if you open the PDF in any of the PDF-viewer you might try to select text, you won't get anything selected, do you?
Therefor you don't get text objects in AutoCAD.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
en respuesta a: engineersafiullah5
You can look/discover for yourself in your PDF viewer that this PDF contains no text objects. like this
And this trick: zoom in real close, if it is broken up with fuzzy edges, you have no font/text in use
You will need to find a 3rd party converter that also has advanced built-in "text recognition": they are out there, test before you buy one (or more).
HTH
