01-19-2022
05:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-19-2022
06:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-19-2022
06:36 AM
Well, you can put a single text in common inside the Index Label in the properties palette, that would modify them all with a unique content.
You can also use TEXTEDIT and change the mode with the Multiple setting.
This allows you to select many texts and not forget one of them... can be practicle...
01-19-2022
09:01 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
01-19-2022
09:01 AM
@cleftwich wrote:edit multiple mtext bodies at once
Please clarify.
If you are referring to its Properties, you can use the QSELECT (Command) and edit multiple MText "bodies" at once.
Otherwise, if its content related, see @imadHabash comment.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
