- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
You can use the following objects and subobjects with LOFT command:
| Objects That Can Be Used as Cross Sections | Objects That Can Be Used as a Loft Path | Objects That Can Be Used as Guides |
2D polyline | Spline | 2D spline |
| 2D solid |
2D spline | Helix | 3D spline |
Arc | Arc | Arc |
Circle | Circle | 2D polyline Note: 2D polylines can be used as guides if they contain only 1 segment. |
| Edge sub-objects | Edge subobjects | Edge subobjects |
Ellipse | Ellipse | 3D polyline |
Elliptical arc | Elliptical arc | Elliptical arc |
| Helix | 2D polyline | |
Line | Line | Line |
| Planar or non-planar face of solid |
| Planar or non-planar surface |
Points (first and last cross section only) | 3D polyline |
| Region |
| Trace |
By plain-cliking the object, you select the entire 3D Solid (not a valid LOFT input).
By ctrl-clicking the object, you select only the surface behind the cursor/crosshair (Subobject Selection).
In addition, you can control-click on Solid Edge (blue) or Solid Vertex (red):
Furthermore, if you turn to the 3D Basics or 3D Modelling workspaces (bottom right gear icon), you'll find the Selection Ribbon Panel.
Select the desired Suboject filter and use any of the Window, Clossing Polygon, Fence or Lasso Selection methods without holding the CTRL key.
