davidschnegg7
en respuesta a: davidschnegg7
Thank you for your help with this.  I just have to change my habit of snapping from a distance.  I typically snap from further away when I have a lot of lines that are close together.  This way I can easily see that I'm at the exact point I want.
In my opinion though... if I'm an inch away from the actually endpoint...  and autocad pops up with the endpoint snap.  The rectangle should be correct, but it's not.
