01-15-2022
08:00 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-15-2022
08:00 PM
Is it possible to manually enter the first input of a rectangle, and then select a snap point for the second dimension. As you can see below I started a rectangle at the top left corner of the existing rectangle. I then entered 0.75" for the width of the rectangle. Then I hit Tab and I wanted to snap to the bottom corner of the existing rectangle. It shows that I selected the endpoint, but you can see it doesn't work. What am I missing here?
¡Resuelto! Ir a solución.
