BIMologist_
906 Vistas, 3 Respuestas
AUTOCAD Alert Disregard Drawoder popup
When I am exploding and I get this error
Is there a way to suppress this Popup as it kills a SCRIPT I am running.,
?Is there is sysvar or registery entry to kill this popup
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
Etiquetas (3)
rkmcswain
en respuesta a: BIMologist_
I suspect setting EXPERT to 5 has no effect. I think the current day programmers are not aware of this variable or otherwise have chosen no to make use of it.
pendean
What is it that you are exploding?
hmsilva
Untested,
in your SCRIPT
set DRAWORDERCTL to 0
explode
set DRAWORDERCTL to 3
Hope this helps,
Henrique
