RandyBenson
292 Vistas, 3 Respuestas
Where can I set the DEFAULT command line transparency when the command line is floating?
Hi folks,
The default transparency for the command window seems to be set at 70% when it is 'floating, not active' above other windows. I'm trying to disable its transparency entirely. I know it can be set on a one-time basis by clicking on the wrench, but there doesn't appear to be an option to set the default.
