leeminardi
en respuesta a: Anonymous
I would recommend using 3ds Max to get the most control in the animating of individual objects in the scene, material appearance, camera motion, lighting and background geometry and images.  For ease and efficiency I would model (or just export) the centerline of scaffolding tubing and angle iron.  You can assign a cross-section shapes in 3ds Max (square, round, etc.).  I usually place all the tubing of the same OD to the same layer in AutoCAD and then can easily set the corresponding render thickness after they are imported to 3ds Max.
BTW, 3ds Max would let you merge real pictures or video with your CAD model.
~Lee
lee.minardi
