acicci
en respuesta a: pendean
sorry I replied to myself
angle at 10 degress.
If I use the line command and draw the line, but specify the angle to be 10 degrees. so 10 degrees from the default  WCS X plane
Use UCS. I type "UCS" then trace along my line I've drawn, this realigns my x plane to the line, which is at a 10 degree angle from the default X plane
What am I trying to do. I have a project with many partitions that do not run perpendicular to each other. I am constantly reorienting my UCS. I need to be able to accurately enter angles while in a UCS different from the WCS
I have found that the problem is only occuring when "DYNMODE" is set to 1, if that helps.
