12-22-2021
01:54 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-22-2021
01:54 PM
UCSFOLLOW interaction with specifying angles
Is this normal behaviour:
When I set my UCSFOLLOW to 1, so that my view rotates to match my new UCS, any angle I draw in that UCS will add the angle of the x plane to the angle I'm drawing.
So let's say I have an angle at 10 degrees. I use UCS (with UCSFOLLOW set to 1) and trace along that line to rotate my view. If I then draw a line and specify the angle at 90, then the line will draw (in relation to my original 10 degree line) at 100, which is also at 110 from my WCS x value. Is this normal?
