- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
UCSFOLLOW interaction with specifying angles
Is this normal behaviour:
When I set my UCSFOLLOW to 1, so that my view rotates to match my new UCS, any angle I draw in that UCS will add the angle of the x plane to the angle I'm drawing.
So let's say I have an angle at 10 degrees. I use UCS (with UCSFOLLOW set to 1) and trace along that line to rotate my view. If I then draw a line and specify the angle at 90, then the line will draw (in relation to my original 10 degree line) at 100, which is also at 110 from my WCS x value. Is this normal?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Like where? how? Explain, elaborate please.
>>>... I use UCS and trace...<<<
Use it how? What options/steps are you employing?
What exactly are you trying to draw/do ultimately if I may ask?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
angle at 10 degress.
If I use the line command and draw the line, but specify the angle to be 10 degrees. so 10 degrees from the default WCS X plane
Use UCS. I type "UCS" then trace along my line I've drawn, this realigns my x plane to the line, which is at a 10 degree angle from the default X plane
What am I trying to do. I have a project with many partitions that do not run perpendicular to each other. I am constantly reorienting my UCS. I need to be able to accurately enter angles while in a UCS different from the WCS
I have found that the problem is only occuring when "DYNMODE" is set to 1, if that helps.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
sorry I replied to myself
