GeeHaa
392 Vistas, 2 Respuestas
AutoCAD freezes shortly after changing to modelspace or while auditing.
I have about 20 drawings with the problem stated above.
Here is what I tried. The drawing opens In paperspace but that's it.
Item                                                    Result
Audit                                                   Freezes
Recover                                              Freezes
Save                                                    Freezes
Quit/End                                             Freezes
Purge    + regapps                            works but still won't save and freezes when switching to model space
Insert as  XREF in a new drawing then OPEN xref             Freezes
Can't Copy and Paste                       Freezes
Export Layout to Model                   works but freezes when you open the new drawing
Plot to PDF                                        Works but importing pdf back to AutoCAD requires allot of fixing
I checked out the xreF to the drawings and its fine no audit errors.
I wrote a program that copies everything in modelspace and paperspace to a new drawing. Works but then the new drawing has the same problems
I would post one of the drawings, but the powers that be won't let me. However I could email one directly to someone directly at Autodesk. So if someone Directly at Autodesk would contact me it would be much appreciated.
G.
