- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have about 20 drawings with the problem stated above.
Here is what I tried. The drawing opens In paperspace but that's it.
Item Result
Audit Freezes
Recover Freezes
Save Freezes
Quit/End Freezes
Purge + regapps works but still won't save and freezes when switching to model space
Insert as XREF in a new drawing then OPEN xref Freezes
Can't Copy and Paste Freezes
Export Layout to Model works but freezes when you open the new drawing
Plot to PDF Works but importing pdf back to AutoCAD requires allot of fixing
I checked out the xreF to the drawings and its fine no audit errors.
I wrote a program that copies everything in modelspace and paperspace to a new drawing. Works but then the new drawing has the same problems
I would post one of the drawings, but the powers that be won't let me. However I could email one directly to someone directly at Autodesk. So if someone Directly at Autodesk would contact me it would be much appreciated.
G.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can reach Autodesk Support this way (hint, Xmas/NY weeks are not a good time for urgent help) https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
In the meantime... Ask the file creator to fix them for you then resend: are they using AutoCAD or something else?
If AutoCAD, they need to go through these steps (you could try the other tips yourself too) https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
HTH
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I found a way to fix it. If I save the file as a DXF, Close it and reopen, then save back to dwg. it seems to solve the Freezing problem.
