Alfred.NESWADBA
en respuesta a: Anonymous
>> Why do the linetype scales change when I create an eps file using psout?
Linetypes in AutoCAD are completely different to linetypes in EPS. In AutoCAD you can create quite complex linetypes based on line-segments, characters and symbols, nothing of that is possible with EPS so the export has to convert entities.
I don't know your workflow, so which software then should import the EPS, but I would suggest to export all lines with linetype continuous and assign the linetypes in the software you are continue to work with the geometry.
For other/better suggestions let us know what exactly changed (show your AutoCAD screenshot and the screenshot where you then imported the EPS so we can see what changed and let is know a bit of your workflow.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
